Adding Calculated Columns
NOTE |
· User defined columns can only be added when there is an available data source. · The user-defined columns are added in the topmost data source in the Data Sources list or in the joined or combined data source. · An auto key can only be created once. · Ranking requires a numeric source column. · Time bucketing requires a time source column and each source column can only be used once. · Numeric bucketing requires a numeric source column. · Text grouping requires a text source column. · The added user-defined column
displays on the Data Preview with a pen symbol
