Object Properties
This option is used to visualize and edit some of the parameters of every geometrical element.
When selecting this option, and having selected an object, the following menu appears:
Figure 1. Object Properties Menu
The following parameters may be modified within this panel:
  • Name objects may be renamed.
  • Layer objects may be moved from their current layer to different ones.
  • Level of Detail (Render) change this bar to increase or decrease the resolution of rendering.
By depending on the type of selected object, different properties that can not be modified within this panel are shown.
A table can also be seen in the bottom right indicating the properties of the surfaces.
Figure 2. Object Properties
