Move (Ctrl+X)
An object can be moved into another position. After clicking on the Edit → Move button, different options to select the objects to be moved are available:
- Move Selection multiple objects can be selected by pressing simultaneously “Ctrl + Left Mouse button”.
- Move All to select all existing objects in the geometry.
With this option the user can select the object to move by entering the coordinates where it should be placed or by clicking directly on the surface and pressing enter.
For example, if we want to move the object in the previous figure of the Copy section, we click on the object and select move. For the sake of illustration, we explode the box and then select only one of the exploded surfaces, after that, we introduce the origin and destination points. The result is shown in the following Figure.
