Example Exercise and Reference
Learn about material properties and walk through the steps to modify an existing material and save it as a new material.
The following PDF shows you how you can use fitting data and material properties to create new materials in Inspire Mold. An exercise at the end provides you with the material properties that you can apply to an existing material to create Vydyne R543H BK02, a popular material made by Ascend Polymers.
Materials Example and Reference
