Creating a Remote Service
Note: You must first enable Use HyperXtrude Job Manager in Preferences > Inspire Extrude Run Options.
  1. Click the Run menu under the Analysis tool.
  2. Click Add Server to add a remote server.
    Dialog to add a new service pops up. This dialog is prepopulated with default data to help in entering the correct paths.
  3. Click Save to add the service.
  4. Click Advanced to access the complete job manager setup.
