Radial
A radial draw direction is a type of manufacturing constraint. It is used when a machining tool needs to enter in a radial direction toward the center of the plane.
Apply a Radial Draw
Select the Radial Draw tool and click on a design space to apply a radial draw constraint.
- Click the icon on the microdialog to eliminate internal voids in the optimized part.
- Click the icon on the microdialog to designate parts as obstacles.
