Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Create polymesh objects from other types of geometry and results.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
View and edit the construction history of your model.
Create and assign variables to parameters when modeling.
Global references are the global origin, axes, and planes shown in the modeling window. They can be helpful when creating and defining your model.
Create and modify parametric surfaces and solids.
Use the Fill tool to convert a solid part to a unit cell lattice.
Use the Convert tool to create NURBS surfaces from a unit cell lattice.
Use the Shrinkwrap tool to surround parts with a single isosurface.
Use the Smooth tool to smooth mesh geometry.
Create free-form solid geometry that is smooth and continuous.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Set up and run an additive manufacturing, porosity, or thinning analysis.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
