/VISC/PRONY
Block Format Keyword This is an isotropic visco-elastic Maxwell model that can be used to add visco-elasticity to certain shell and solid element material models. The visco-elasticity is input using a Prony series.
| /VISC/PRONY/mat_ID/unit_ID | |||||||||
| M | |||||||||
| mat_ID | Material identifier which
refers to the viscosity card (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| M | Maxwell model order
(number of Prony coefficients). Default = 0 (Integer) |
| Viscous bulk modulus.
3 Only used if
. Default = 0. (Real) |
| Shear relaxation modulus
for ith term
(i=1,
M). (Real) |
| Decay shear constant for
ith term
(i=1,
M). (Real) |
| Bulk relaxation modulus
for ith term
(i=1, M). 3 (Real) |
| Decay bulk constant for
ith term
(i=1,
M). (Real) |
- For shell elements this model is
available with /MAT/LAW66 and
/MAT/LAW25 (COMPSH).
For solid elements it is available with material laws /MAT/LAW38 (VISC_TAB), /MAT/LAW42 (OGDEN), /MAT/LAW69, /MAT/LAW70 (FOAM_TAB), /MAT/LAW82, /MAT/LAW88, /MAT/LAW90, /MAT/LAW92, /MAT/LAW103 (HENSEL-SPITTEL), and /MAT/LAW106 (JCOOK_ALM).
- The viscosity effect is taken into
account by using a Prony series. The deviatoric viscous stress is given by the
convolution integral of the form:
(1) with(2) and denotes the deviatoric part of strain tensor.
Shear decay:(3) Where, is the relaxation time.
- For the viscous pressure, two formulations are
available:
- If the bulk relaxation modulus is
, the viscous pressure is computed
as:
(4) with and
and the viscous bulk modulus
as:
(5)
as:
- Starting with Radioss version 2017, identical results are obtained using the same Prony coefficents Gi in /VISC/PRONY and viscoelastic materials /MAT/LAW34 (BOLTZMAN), /MAT/LAW40 (KELVINMAX), and /MAT/LAW42 (OGDEN). In previous Radioss versions, 2 Gi had to be input into /VISC/PRONY to get equivalent results.
