Newarks Method
Newmark's method is a one step integration method. The state of the system at a given time t n + 1 = t n + h is computed using Taylor's formula:(1)
f ( t n + h ) = f ( t n ) + h f ′ ( t n ) + h 2 2 f ( 2 ) ( t n ) + ... + h s s ! f ( s ) ( t n ) + R s
(2)
R s = 1 s ! ∫ t n t n + h f ( s + 1 ) ( τ ) [ t n + h − τ ] s d τ
The preceding formula allows the computation of displacements and velocities of the system at time t n + 1 :(3)
u ˙ n + 1 = u ˙ n + ∫ t n t n + 1 u ¨ ( τ ) d τ
(4)
u n + 1 = u n + h u ˙ n + ∫ t n t n + 1 ( t n + 1 − τ ) u ¨ ( τ ) d τ
The approximation consists in computing the integrals for acceleration in Equation 3 and in Equation 4 by numerical quadrature:(5)
∫ t n t n + 1 u ¨ ( τ ) d τ = ( 1 − γ ) h u ¨ n + γ h u ¨ n + 1 + r n
(6)
∫ t n t n + 1 ( t n + 1 − τ ) u ¨ ( τ ) d τ = ( 1 2 − β ) h 2 u ¨ n + β h 2 u ¨ n + 1 + r ′ n
By replacing Equation 3 and Equation 4, you have:(7)
u ˙ n + 1 = u ˙ n + ( 1 − γ ) h u ¨ n + γ h u ¨ n + 1
(8)
u n + 1 = u n + h u ˙ n + ( 1 2 − β ) h 2 u ¨ n + β h 2 u ¨ n + 1 + r ′ n
According to the values of γ and β , different algorithms can be derived:
  • γ = 0 , β = 0 : pure explicit algorithm. It can be shown that it is always unstable. An integration scheme is stable if a critical time step exists so that, for a value of the time step lower or equal to this critical value, a finite perturbation at a given time does not lead to a growing modification at future time steps.
  • γ = 1 / 2 , β = 0 : central difference algorithm. It can be shown that it is conditionally stable.
  • γ = 1 / 2 , β = 1 / 2 : Fox & Goodwin algorithm.
  • γ = 1 / 2 , β = 1 / 6 : linear acceleration.
  • γ = 1 / 2 , β = 1 / 4 : mean acceleration. This integration scheme is the unconditionally stable algorithm of maximum accuracy.
