/TH/VERS
Engine Keyword Generates the Time History files in Radioss environment post-processing format "Version Number".
/TH/VERS/Version Number
| Version Number |
Radioss Version 41, 51 or
2021. Default = 41 |
- Starting in Radioss Version 51:
- The length of the time history file titles was increased from 40 to 100 characters.
- The time history file name is changed from <root_name>.T01 to <root_name>_0001.thy.
- Starting in Radioss Version 2021, 3 new outputs for contact energies
in the global output and interface output are added:
- CE_ELAST: Elastic contact energy which is the recoverable energy stored in contact penalty springs.
- CE_FRIC: Frictional contact energy.
- CE_DAMP: Damping contact energy.
