/TH/SPRING
Block Format Keyword Describes the time history for springs.
| /TH/SPRING/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| elem_ID | elem_name | ||||||||
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| elem_ID | Element
identifier (Integer) |
| elem_name | Name of the element to
appear in the time history (Integer, maximum 80 characters) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SPRING | Springs | OFF, FX, FY, FZ, MX, MY, MZ, LX, LY, LZ, RX, RY, RZ, IE, F1, F2 |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SPRING | DEF | OFF, FX, FY, FZ, MX, MY, MZ, LX, LY, LZ, RX, RY, RZ, IE |
Output for Spring
- OFF: element flag for deactivation 4
- FX: force in direction X
- FY: force in direction Y
- FZ: force in direction Z
- F1 and F2 (only available for /PROP/TYPE12 (SPR_PUL)) are internal forces of each spring force.
- MX: moment in direction X
- MY: moment in direction Y
- MZ: moment in direction Z
- LX: elongation in direction X 5
- LY: elongation in direction Y 5
- LZ: elongation in direction Z 5
- RX: rotation around X axis in radians
- RY: rotation around Y axis in radians
- RZ: rotation around Z axis in radians
- IE: internal energy
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- For all spring properties except /PROP/TYPE8 (SPR_GENE), /PROP/TYPE28 (NSTRAND) and /MAT/LAW108 (SPR_GENE), the forces and moments are given in the local element system. The element system is defined with the spring nodes or the local skew defined in the property.
- For the spring /PROP/TYPE8 (SPR_GENE) or /MAT/LAW108 (SPR_GENE), the forces and moments are given in the global system; except when a local skew is defined in the property. In this case, the forces and moments are given in the defined local system.
- OFF:
- 0.0 deleted element
- 1.0 active element
- 2.0 (shells / solids): active element using small strain
- Negative value -1/-2 when the element is on stand-by due to rigid body
Some intermediate values can be found during few cycles before element deletion (progressive reduction of off during a few cycles applies as a multiplicative factor to the stress, so that the stress is progressively vanished and element is deleted after ~ 10 cycles). This process applies to some element types, but not all.
- For spring type 29, 30, 31, 32, 35, 36, 44, 45 and 46 the output is elongation speed of the spring.
