/TH/CLUSTER
Block Format Keyword Describes the time history output of spotweld clusters.
| /TH/CLUSTER/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
Descriptions
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| CLUSTER | Spotweld Cluster | FX, FY, FZ, MX, MY, MZ, FAIL, FN, FT, MB, MT |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| CLUSTER | DEF FLOC |
FAIL FN, FT, MB, MT |
- Spotweld cluster is defined with the /CLUSTER card.
- Use parameter Ifail=1 in /CLUSTER for output of FAIL variable.
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
