/TH/ACCEL
Block Format Keyword Describes the time history for accelerometers.
| /TH/ACCEL/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| ACCEL | Accelerometer | AX, AY, AZ, WX, WY, WZ |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| ACCEL | DEF W | AX, AY, AZ, WX, WY, WZ |
Output for Accelerometer
- AX: acceleration in direction X
- AY: acceleration in direction Y
- AZ: acceleration in direction Z
- WX: integral of acceleration in direction X
- WY: integral of acceleration in direction Y
- WZ: integral of acceleration in direction Z
- Let the nodal acceleration vector with laboratory expressed in the global skew system, the nodal acceleration vector with laboratory projected onto the moving skew.
Let the nodal velocity vector with laboratory expressed in the global skew system, the nodal velocity vector with laboratory projected onto the moving skew.
This shows that derivating the nodal velocity with laboratory projected onto the moving skew, does not give as a result the nodal acceleration with laboratory projected onto the moving skew, .
Derivating to this output will give a value of nodal acceleration with laboratory projected onto the moving skew, the integration-derivation acting as another filter other than the 4-pole Butterworth, which is used in the accelerometer and computes the filtered accelerations AX, AY, and AZ.
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
