/PROP/TYPE0 (VOID)
Block Format Keyword This property is used to define the void property set.
| /PROP/TYPE0/prop_ID/unit_ID or /PROP/VOID/prop_ID/unit_ID | |||||||||
| prop_title | |||||||||
| Thick | |||||||||
| prop_ID | Property
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| prop_title | Property
| Thick | Thickness (Real) |
- Void property is only compatible with void material.
- An optional format is available.
- This additional data allows to define contact interfaces with void material and property: all kinds of input for interfaces will then be available (Igap =1, Stfac as a stiffness factor).
- Contact stiffness will be correctly calculated only when Thick is entered. If there is no thickness entered, the elements with this property will have no contact stiffness.
