Multi-Domain Keyword Specifies the RAD2RAD printout frequency.
/PRINT/Nprint
| Nprint | Printout is made by RAD2RAD every Nprint cycle |
- If the printout frequency is not defined, RAD2RAD will use the smallest of the printout frequencies of Radioss Engine.
