Model Checking by Radioss Starter
Radioss Starter checks for consistency between format
lines and prompts errors and warnings, if they exist. The output file
runname_0000.out contains useful information helping to debug
models.
- Errors and Warnings Messages
- All errors must be corrected
- Check Time Step (element and nodal)
- How many elements control time step? If a few, then modify the mesh to optimize the time step.
- Check Mass and Inertias
- Mass scaling causes instability. It is worthwhile to check the center of gravity computed by Radioss. That should fit the physical center of gravity.
