/MESH
Multi-Domain Keyword Defines the space of Lagrange multipliers in the case of incompatible meshes.
/MESH/Type (facultative)
| Type |
- The optimal method is used by default, as it is more accurate.
- Mortar methods could be used to reduce the number of Lagrange multipliers to be computed and then the CPU cost of RAD2RAD. But by using the Mortar methods, the continuity condition between domains is no longer exactly ensured.
