/MAT/LAW20 (BIMAT)
Block Format Keyword ALE multi-material law for 2D analysis.
| /MAT/LAW20/mat_ID or /MAT/BIMAT/mat_ID | |||||||||
| mat_title | |||||||||
| Blank Line | |||||||||
| mat_ID1 | mat_ID2 | IC1 | IC2 | IDISCRETE | |||||
| mat_ID | Material
| mat_title | Material
| mat_ID1 | First material identifier
(ALE or Euler material) (Integer) |
| mat_ID2 | Second material identifier
| IC1 | Incoming mat_ID1
control flag (Integer) |
| IC2 | Incoming mat_ID2
| IDISCRETE | Discrete filling
flag (Integer) |
| Ratio of first
material (Real) |
| Ratio of second
material (Real) |
Example (Steel)
#RADIOSS STARTER
/MAT/LAW20/1
steel (unit: g_cm_mus)
# BLANK CARD
# mat_ID1 mat_ID2 IC1 IC2 Idiscrete
8 9 0 0 0
# Alpha1 Alpha2
0.82 0.18
/ALE/MAT/1
# Modif. factor.
0
/MAT/HYD_JCOOK/8
steel
# RHO_I RHO_O
7.8899999 0
# E nu
2.0999999 .30000001
# A B n epsmax sigmax
.011 .00275 .36000001 0 0
# Pmin
1E-10
# C EPS_DOT_0 M Tmelt Tmax
.022 1E-6 1 1811 2000
# RHOCP
3.5699999E-5
/EOS/POLYNOMIAL/8
steel
# C0 C1 C2 C3
0 1.6900001 3.0999999 0
# C4 C5 E0 Psh RHO_0
1.83 1.83 0 0 0
/MAT/HYD_JCOOK/9
tungstene
# RHO_I RHO_O
17.6 0
# E nu
3.5999999 .30000001
.01506 .00177 .12 0 0
# Pmin
1E-10
.016000001 1E-6 1 3400 3400
# RHOCP
2.36E-5
/EOS/POLYNOMIAL/9
tungstene
# C0 C1 C2 C3
0 2.8199999 2 -1.37
1.54 1.54 0 0 0
#ENDDATA
- Compatible with 2D Analysis only (/ANALY). Material must be defined as an ALE (/ALE/MAT) or EULER (/EULER/MAT) material.
- and are initial percentages of mat_ID1 and mat_ID2.
- Material identifiers mat_ID1 or mat_ID2 cannot be used with material LAW11.
- Only material type LAW20 can be frontier to the material LAW20.
- Activating flag for incoming material control (ICi = 1) enables filtering incoming material mat_IDi.
- Activating flag for discrete filling (IDISCRETE = 1) enables old initial filling (version 10.0.3 and prior) for all Bimaterial laws in the input file. Partial filling for other bimaterial laws is not taken into account.
