/LEAK/MAT
Block Format Keyword Specifies effective leakage area of porous airbag fabric materials LAW19 and LAW58 as function of time, pressure, area and other parameters.
| /LEAK/MAT/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| Ileakage | AscaleT | AscaleP | |||||||
| AC' | fct_IDAC' | FscaleAC' | |||||||
| LC | AC | ||||||||
| fct_IDLC | fct_IDAC | FscaleLC | FscaleAC | ||||||
| L | R | ||||||||
| C1 | C2 | C3 | |||||||
| X0 | X1 | X2 | X3 | ||||||
| mat_ID | Material
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| mat_title | Material
| Ileakage | Effective leakage area
formulation flag.
(Integer) |
| AscaleT | Abscissa time scale factor
on function Default = 1 (Real) |
| AscaleP | Abscissa pressure scale
factor on function Default = 1 (Real) |
| AC' | Area coefficient for area
in contact
Default = 0 (Real) |
| fct_IDAC' | Area coefficient function
identifier AC'(t) if AC' is equal to 0 (Integer) |
| FscaleAC' | Scale factor on function
AC' Default = 1 (Real) |
| LC | Leakage
coefficient Default function is 0 (Real) |
| AC | Area coefficient Default = 0 (Real) |
| fct_IDLC | Leakage coefficient
function identifier LC(t), if Ileakage
=2 or 3 Leakage coefficient function identifier , if Ileakage =4 Default function is 0 (Integer) |
| FscaleLC | Scale factor on function
LC Default = 1 (Real) |
| fct_IDAC | Area coefficient function
identifier
, if Ileakage
=2. Area coefficient function identifier , if Ileakage =3. Area coefficient function identifier , if Ileakage =4. Default function is 0 (Integer) |
| FscaleAC | Scale factor on function
AC Default = 1 (Real) |
| L | Characteristic
length Default = 1 (Real) |
| R | Fiber thickness Default = L (Real) |
| C1 | Coefficient
C1 (Real) |
| C2 | Coefficient C2 Default = 1 (Real) |
| C3 | Coefficient
C3 (Real) |
| X0, X1, X2, X3 | Coefficients of
Anagonye-Wang leakage area law (Real) |
- The mat_ID must be the same as /MAT/LAW19 (FABRI) or /MAT/LAW58 (FABR_A). Material porosity is active only when corresponding components are referred as external surfaces in /MONVOL/AIRBAG1, /MONVOL/COMMU1, and /MONVOL/FVMBAG1 airbag cards.
- Effective leakage area (
) formulation:Ileakage =1:
(1) Ileakage =2:(2) Ileakage =3:(3) Ileakage =4:(4) Where,- Initial area of the airbag surface
Note: By default all coefficients and functions are zero.Ileakage =5:(5) Where, and are the stretches in warp and weft directions and is the angle between warp and weft directions.Note: For LAW19Ileakage =6:(6) with and
- Blockage of airbag fabric, due to
contact, can be activated in corresponding /MONVOL card.
Effective leakage area is calculated with account of the blockage as:
(7)
