/LAGMUL
Block Format Keyword Describes the Lagrange multiplier option.
| /LAGMUL | |||||||||
| Lagmod | Lagopt | Tol | Alpha | Alpha_s | |||||
| Lagmod | Conjugates gradient
pre-conditioning algorithm.
(Integer) |
| Lagopt | Lagrange multiplier matrix
scaling option.
(Integer) |
| Tol | Convergence
criteria. Default = 1.E-11 (Real) |
| Alpha | Iterative shift
parameter. Default = 0.001 (Real) |
| Alpha_s | Initial shift
value. Default = 0.0 (Real) |
- The Tol value defines
a solver precision tolerance for the kinematical conditions treated by Lagrange
multipliers:
/BCS/LAGMUL, /GJOINT, /IMPVEL/LAGMUL, Lagrange Multiplier Method, /MPC, /RWALL/LAGMUL, and /RBODY/LAGMUL
- Alpha and Alpha_s are only used with Cholesky pre-conditioning, and may be used to optimize the matrix factorization speed and quality. These are parameters added to matrix diagonal to avoid failure of incomplete factorization algorithm.
- Kinematical conditions in Radioss solver may be optionally treated by a Lagrange
multiplier method.
These conditions are incompatible with standard kinematical conditions, and a warning is issued in Starter if an attempt to merge different solution methods for the same nodes is made.
Otherwise, all Lagrange multiplier conditions are compatible; except in cases of physical incompatibility.
