/KEREL/1
Engine Keyword Kinetic energy relaxation applied to node group grnd_ID.
/KEREL/1
grnd_ID
Tstart Tstop
| grnd_ID | Node group identifier. | |
| Tstart | (Optional) Start time for
kinetic energy relaxation. Default = 0.0 |
| Tstop | (Optional) Stop time for
kinetic energy relaxation. Default = Final time of the analysis |
- Can be used only if Starter Input uses Block Format.
- It is not advised to use /KEREL/1 with combined Advanced mass Scaling and Single Precision.
- If the maximum kinetic energy is reached due to the elastic vibration of shell or solid part, the result can be wrong because the stress, strain and strain rate tensors in the element will no longer be in equilibrium.
