/INIV/AXIS/Keyword3/1
Engine Keyword Initialize rotational velocity about an axis and translational velocity.
Frame_ID
VXt VYt VZt Vr
N1first, N2last..., Nifirst, Nilast
| Field | Contents | Si Unit Example |
| Keyword3 | Direction X, Y, and Z of the frame defining the rotation axis. | |
| Frame_ID | Frame
identifier. (Integer) |
| VXt , VYt , VZt , Vr | Translational velocity
components in the local frame and rotational velocity about the
axis. (Real) |
or |
| N1first, N2last..., Nifirst, Nilast | First and last list of nodes. |
- If frame_ID is not zero, the initial velocities are applied with respect to this local frame.
- Once
is expressed in the global system, the
velocities are initialized with respect to:
(1) Where,- Vector defining the rotation axis
- Represents a point on the axis and is set as the origin of the frame.
