/INIBRI/AUX
Block Format Keyword Describes the initial state for a brick.
| /INIBRI/AUX/unit_ID | |||||||||
| brick_ID | Nb_integr | Isolnod | Isolid | nvars | |||||
| V1 | Vnvars | ||||||||
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| brick_ID | Element
identifier. (Integer) |
| Nb_integr | Number of integration
points. Corresponds to the property definition of this element. (Integer) |
| Isolnod | Number of nodes of solid
| Isolid | Solid elements
formulation. It corresponds to the solid elements formulation of in property definition of this element. (Integer) |
| nvars | Number of auxiliary
internal variables. (Integer) |
| V1 | First auxiliary
variable. (Real) |
| Vnvars | Nvarsth
auxiliary variable value. (Real) |
- If AUX, three values per line for auxiliary internal variables.
- If AUX, format line 3 has to be repeated in order to have nvars auxiliary internal variables.
- The initial state for brick may be defined by more than one block.
