/GRQUAD/QUAD
Block Format Keyword Describes the quad number groups.
/GRQUAD/QUAD/grquad_ID/unit_ID | |||||||||
grquad_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
grquad_ID | Quad group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grquad_title | Quad group
item_ID1, item_ID2,..., item_IDn | List of quad
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
