/GRNOD/BOX
Block Format Keyword Describes the node box groups which are inside the box.
/GRNOD/BOX/grnd_ID/unit_ID | |||||||||
grnod_title | |||||||||
box_ID |
grnd_ID | Node group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grnd_title | Node group
box_ID | Box identifier, which
is defined in Boxes (Integer, maximum 10 digits) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- Nodes are stored in this order. For all other input types, nodes are sorted.
- If type is BOX, all nodes inside the box are selected.
