/GRBEAM/GENE
Block Format Keyword Generate a group of beam elements by listing the first and last element IDs in the range.
/GRBEAM/GENE/grbeam_ID/unit_ID | |||||||||
grbeam_title | |||||||||
first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
grbeam_ID | Beam group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grbeam_title | Beam group
first_ID1, last_ID1,..., first_IDn, last_IDn | List of first and last
beam identifiers (Integer) |
