/FAIL/CONNECT
Block Format Keyword Describes the failure model for CONNECTION material with displacement criteria and/or energy criteria.
/FAIL/CONNECT/mat_ID/unit_ID | |||||||||
expN | R_fct_IDN | Ifail | Ifail_so | ISYM | |||||
expT | R_fct_IDT | ||||||||
EImax | ENmax | ETmax | Nn | Nt | |||||
Tmax | Nsoft | AREAscale |
fail_ID |
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
Failure relative displacement in normal
direction. Default = 1030 (Real) |
expN | Failure exponent parameter in normal
direction. Default = 1.0 (Real) |
Normal direction scale factor. Default = 1.0 (Real) |
R_fct_IDN | Identifier for
failure scale factor
in normal direction versus displacement rate
function. (Integer) |
Ifail | Failure formulation flag. 2
(Integer) |
Ifail_so | Solid failure flag.
(Integer) |
ISYM | Rupture deactivation flag for compression.
(Integer) |
Failure relative displacement in tangential
plane. Default = 1030 (Real) |
expT | Failure exponent parameter in tangential
plane. Default = 1.0 (Real) |
Scale factor in tangential plane. Default = 1.0 (Real) |
R_fct_IDT | Identifier for
in tangential plane versus displacement rate
EImax | Failure internal energy, per surface
unit. Default = 1030 (Real) |
ENmax | Normal failure internal energy, per surface
ETmax | Tangential failure internal energy, per surface
Nn | Exponent for normal energy failure
criteria. Default = 1.0 (Real) |
Nt | Exponent for tangential energy failure
Tmax | Duration parameter for energy failure
criteria. (Real) |
Nsoft | Softening exponent for failure. Default = 1.0 (Real) |
AREAscale | Failure scale factor for area increase. 6 Default = 0.0, this option is not used (Real) |
fail_ID | Failure criteria
identifier. 4 (Integer, maximum 10 digits) |
Example (Spotweld)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW59/1/1
spotweld
# RHO_I
7.9E-9
# E G Imass
21000 21000 0
# NB_fct Fsmooth Fcut
1 1 0
# YFun_IDN YFun_IDT SR_ref Fscale_yld
1 2 0 0
/FAIL/CONNECT/1
# EPS_MAX_N EXP_N ALPHA_N R_fct_IDN Ifail Ifail_so ISYM
1 0 0 0 0 1 0
# EPS_MAX_T EXP_T ALPHA_T R_fct_IDT
1.8 0 0 0
# EIMAX ENMAX ETMAX Nn Nt
0 0 0 0 0
# Tmax Nsoft AREAscale
0 0 0
#- 3. FUNCTIONS:
/FUNCT/1
New_function
# X Y
0 250
1 350
/FUNCT/2
New_function
# X Y
0 350
1 350
#ENDDATA
/END
- This failure model is compatible only with the connection material, /MAT/LAW59 (CONNECT).
- Failure criteria:
Solid element failure will occur when displacement values reach the criteria, or when the internal energy reaches the failure internal energy value.
Ifail control coupled or uncoupled failure formulation for are exclusive with each other. Displacement and energy criteria can be used simultaneously. Both energy criteria can be used simultaneously (based on EImax and energy in both directions separately).- Ifail =0: Uni-directional formulation (uncoupled
failure formulation)For displacement criteria:
(1) With = 33 for normal direction and 13 or 23 for tangent directions.
For energy criteria:(2) or, for each direction:(3) or, for total energy:(4) - Ifail=1: Multi-directional formulation (coupled
(5) For energy criteria:(6) With and being the energy in the normal and the tangential direction, respectively.
- A damage variable is defined,
as:
(7) (8) (9) The element is deleted (or stress in local integration point is set to zero), if:(10) If is equal to default value, failure is immediate.
Otherwise, when , softening is applied (for all directions) as:(11) - fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value is output for the failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
- The following animation
(/ANIM/BRICK) and time history
(/TH/BRICK) outputs are
available using USR (maximum value over
integration points):
EImax (only) ENmax or ETmax (only) EImax and (ENmax or ETmax)
USR1 USR2 Where,- EI
- Internal energy per connection element area
- En
- Internal energy in the normal direction per connection element area
- Et
- Internal energy in the shear direction per connection element area
Ifail=0 Ifail=1 USR3 USR4 USR5 USR6 - The area is calculated as the mean value of the upper and lower surface of the solid element. If the actual area reaches the value of initial area multiplied by AREAscale factor, the whole element will be deleted. If the elements attached to the connect elements fail, this option can be used to prevent shooting nodes due to large deformation of the connect elements.
