/FAIL/CHANG
Block Format Keyword Describes the Chang failure model.
| /FAIL/CHANG/mat_ID/unit_ID | |||||||||
| Ifail_sh | |||||||||
| fail_ID |
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| Longitudinal tensile
strength. Default = 1030 (Real) |
| Transverse tensile
| Shear strength. Default = 1030 (Real) |
| Longitudinal compressive
| Transverse compressive
| Shear scaling
factor. Default = 0 (Real) |
| Dynamic time relaxation.
7 Default = 1030 (Real) |
| Ifail_sh | Shell failure model flag.
(Integer) |
| fail_ID | Failure criteria identifier. 6 (Integer, maximum 10 digits) |
- This failure model is available for shell only.
- Where direction one is the fiber
direction. The failure criteria for fiber breakage is written as:Tensile fiber mode:
(1) Compressive fiber mode:(2) - For matrix cracking, the failure criteria is:Tensile matrix mode:
(3) Compressive matrix mode:(4) - If the damage parameter
, or
the stresses are decreased by using an exponential
function to avoid numerical instabilities. A relaxation technique is used by
decreasing the stress gradually:
(5) With,(6) Where,- Time
- Start time of relaxation when the damage criteria is assumed
- Time of dynamic relaxation
- Stress at the beginning of damage
- The damage
value, D is
. The status for fracture is:
- Free, if
- Failure, if
with . This damage value shows with /ANIM/SHELL/DAMA.
- The fail_ID is used with /STATE/SHELL/FAIL and /INISHE/FAIL for shell. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick and with /STATE/SHELL/FAIL for shell).
- After the failure criterion is reached, the value determines a period of time when the stress in the failed element is gradually reduced to zero. When the stress reaches 1% of stress value at the start of failure, the element is deleted. This is necessary to avoid instabilities coming from a sudden element deletion and a failure “chain reaction” in the neighboring elements. Even if the failure criterion is reached, the default value of results in no element deletion. Therefore, it is recommended to define 10 times larger than the simulation time step.
