/FAIL/ALTER
Block Format Keyword An advanced nonlinear stress-based failure criteria for glass applications such as a windshield.
The failure stress is described by parameters defining micro-cracks and crack propagation speed. With the X-FEM approach, the stress is set to zero perpendicular to the crack direction.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) | (9) | (10) | |
| /FAIL/ALTER/mat_ID/unit_ID | ||||||||||
| Exp_n | V0 | Vc | Ncycles | Irate | Iside | mode | ||||
| Cr_foil | Cr_air | Cr_core | Cr_edge | grsh4N | grsh3N | |||||
| KIC | KTH | Rlen | Tdelay | |||||||
| Kres1 | Kres2 | |||||||||
| fail_ID |
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| Exp_n | Crack growth exponent for subcritical
crack growth. Default = 16.0 (Real) |
| V0 | Crack growth velocity for subcritical
crack growth at KIC. Default = 0.0 (Real) |
| Vc | Maximum crack propagation velocity
glass. Default = 0.0 (Real) |
| Ncycles | Stress filtering period in cycles. Only
used when Irate=0. 2
(Integer) |
| Irate | Stress rate filtering method.
(Integer) |
| Iside | Strain rate dependency option.
| mode | Flag to switch failure propagation
models between neighbor elements.
(Integer) |
| Cr_foil | Crack depth at bottom surface. Default = 0.0 (Real) |
| Cr_air | Crack depth at top surface. Default = 1.0 (Real) |
| Cr_core | Crack depth in between bottom and
surface integration points. Default = 1.0 (Real) |
| Cr_edge | Crack depth at the edge elements of
windshield. Default = 1.0 (Real) |
| grsh4N | (Optional) Group identifier for 4 node
edge shell elements. Default = 0 (Integer) |
| grsh3N | (Optional) Group identifier for 3 node
| KIC | Fracture toughness. Default = 0.0 (Real) |
| KTH | Fatique threshold. Default = 0.0 (Real) |
| Rlen | Reference length. Default = 1.0 (Real) |
| fail_ID | Failure criteria
identifier. 9 (Integer, maximum 10 digits) |
| Tdelay | Relaxation time before removing
elements. Default = 0.0 (Real) |
| Kres1 | Residual tensile stress scale factor in
first crack direction. Default = 0.0 (Real) |
| Kres2 | Residual tensile stress scale factor in
second crack direction. Default = 0.0 (Real) |
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
/MAT/LAW36/72200103/1
Glass with linear hardening
# RHO_I
2.50E-9
# E NU Eps_p_max Eps_t Eps_m
70000.0 0.23
# N_funct F_smooth C_hard F_cut Eps_f
1 1 1650.0
# fct_IDp Fscale fct_IDE EInf CE
# fct_ID1 fct_ID2 fct_ID3 fct_ID4 fct_ID5
722001021
# Fscale_1 Fscale_2 Fscale_3 Fscale_4 Fscale_5
1000.0
# Eps_dot_1 Eps_dot_2 Eps_dot_3 Eps_dot_4 Eps_dot_5
0.0
/FAIL/ALTER/72200103/1
# exp_n V0 VC Ncycles Irate Iside mode
16.0 6.0 1520000 6 0 0 1
# cr_foil cr_air cr_edge grsh4N grsh3N
0.00040 0.00100 0.00500
# K_Ic K_Th Rlen Tdelay
23.717 7.9057 1.0 0
# Kres1 Kres2
0 0
/FUNCT/722001021
Function for glass
# X Y
0.0 500.0
1.0 550.0
#enddata
- This failure criteria is using the maximum stress as failure criterion. It is computed based on the strength of the material determined by initial cracks and the crack propagation velocity. Depending on mode switch flag, different failure propagation models between neighbor elements may be used.
- When
Irate=0, an exponential moving average filter is
used, and the filtered stress is:
(1) Where, - This failure model is compatible only with under-integrated shell elements (Ishell =24 and Ish3n =2 are recommended) and not compatible fully integrated shells. Also, although there is no restriction of the shell property that can be used, it is only compatible with one layer shell models.
- The elements defined in the groups grsh4N and grsh3N should be along the edge of the windshield and will receive specific failure weakening.
- This failure model is applied to shell
elements that sandwich a polyvinyl butyral (PVB) solid element layer using coincident
nodes. The entire assembly models a windshield.
Figure 1. Windshield finite element model
Figure 2. Windshield model - entire assembly - The shell elements using this failure model should be oriented so their normals point away the from the middle PVB.
- The shell elements should have an offset applied to correctly model bending. This can be done using /PROP/TYPE51 Ipos=4.
- The fracture limit depends on the location and the fracture state of surrounding elements. 1
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL and /PERTURB/FAIL/BIQUAD. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick and with /STATE/SHELL/FAIL for shell).
