/EOS/PUFF
Block Format Keyword Describes the linear polynomial equation of state .
| /EOS/PUFF/mat_ID/unit_ID | |||||||||
| eos_title | |||||||||
| C1 | C2 | C3 | |||||||
| T1 | T2 | Es | |||||||
| H | E0 | ||||||||
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| eos_title | EOS title. (Character, maximum 100 characters) |
| C1 | C1 coefficient. 1 (Real) |
| C2 | C2 coefficient. (Real) |
| C3 | C3 coefficient. (Real) |
| Gruneisen gamma. (Real) |
| T1 | T1
coefficient. 1 Default = C1 (Real) |
| T2 | T2
| Es | Sublimation energy per unit initial
volume. (Real) |
| H | H coefficient. 1 (Real) |
| E0 | Initial energy per unit initial
volume. (Real) |
| Reference density. Default = material density (Real) |
Example (Copper)
#RADIOSS STARTER
/UNIT/1
unit for mat
g cm mus
#- 2. MATERIALS:
/MAT/HYD_JCOOK/1/1
Copper
# RHO_I RHO_0
8.9 0
# E nu
1.3 .34
# A B n epsmax sigmax
9E-4 .00292 .31 0 0
# Pmin
0
# C EPS_DOT_0 M Tmelt Tmax
.025 1E-6 1.09 1356 1E30
# RHOCP T_r
3.432E-5 0
/EOS/PUFF/1/1
Copper
# C1 C2 C3 G0
1.3597 2.7466 2.4479 1.97
# T1 T2 ES
0 0 0.12282
# H E0 RHO_0
1 1.25675 0
#ENDDATAComments
- Let
and E, the internal energy per unit initial volume, the
pressure is defined by:Region 1:
(1) with
Region 2: and(2) Region 3: and(3) with
- Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
