/EOS/NOBLE-ABEL
Block Format Keyword Describes the covolume equation of state .
| /EOS/NOBLE-ABEL/mat_ID/unit_ID | |||||||||
| eos_title | |||||||||
| b | E0 | Psh | |||||||
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| eos_title | EOS title. (Character, maximum 100 characters) |
| b | Covolume. (Real) |
| Heat Capacity ratio
. (Real) |
| E0 | Initial internal energy per unit
reference volume. (Real) |
| Psh | Pressure shift. (Real) |
| Reference density. Default = material density (Real) |
/UNIT/1
unit for mat
g mm ms
/MAT/HYDPLA/7
NOBLE_ABEL
# RHO_I RHO_0
1.22e-6 0
# E nu
0 0
# a b n eps_max sigma_max
1E30 0 0 0 0
# Pmin Psh
0
/EOS/NOBLE-ABEL/7
NOBLE-ABEL EOS
# b GAMMA E0 PSH RHO0
1E-3 1.4 0.2499999997 0 1.22e-6
/ALE/MAT/7
#enddata
- A generalization of the ideal-gas
thermal EOS,
is the co-volume equation of state
Where,
- Specific volume
- b
- Covolume
- R
- Specific gas constant
- T
- Temperature
Previous form , can be written in form.
Where,with
- This EOS applies to dense gases at high pressure for which the volume occupied by the molecules themselves is no longer negligible.
- Covolume b is usually in range
- Some comparison with ideal gas EOS:
IDEAL-GAS NOBLE-ABEL Sound Speed - Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
