/DT/SPHCEL/Keyword3
Engine Keyword Generates the SPH cells time step control type.
/DT/SPHCEL/Keyword3
| Keyword3 | Time step control type:
If Keyword3 is not specified, that is, /DT/SPHCEL, then the shell elements will use the is not used. |
| Scale factor on time step for option SPHCEL. | ||
| Minimum time step for option SPHCEL. |
- This option can be used with the
/DT/NODA. In such case, the criteria for deleting a
SPH cell (or stopping, or killing the computation) is:
(1) with being the stiffness based on SPH interaction.
- Nodal time step is generally more robust.
