/DT/SHELL
Engine Keyword The time step for shell elements using /DT1 is lower but more accurate. Otherwise, this option is identical to /DT1/SHELL.
/DT/SHELL/Keyword3
| Data | Description | SI Unit Example |
| Keyword3 | Time step control type:
| Scale factor on time step for option defined by Keyword3. | ||
| Minimum time step. |
