/DT
Engine Keyword Time step defaults for all elements.
/DT
| Default scale factor
on time step for all elements. Default = 0.9 |
| Default minimum time step for all elements. |
- If the time step of a simulation reaches , then the following actions will happen depending on which element type is controlling the time step. For /BRICK or /QUAD elements, the simulation stops and a restart file is created. For /SHELL or /SH_3N elements, the element controlling the time step is deleted from the simulation. For all other element types, is not used.
