/DFS/DETPOINT
Block Format Keyword Locates the detonation point and set lighting time for an explosive material law.
| /DFS/DETPOINT/detpoint_ID/unit_ID | |||||||||
| XDET | YDET | ZDET | TDET | mat_IDDET | |||||
| detpoint_ID | Point detonator
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| XDET | X coordinate. Default = 0.0 (Real) |
| YDET | Y coordinate. Default = 0.0 (Real) |
| ZDET | Z coordinate. Default = 0.0 (Real) |
| TDET | Detonation time. Default = 0.0 (Real) |
| mat_IDDET | Explosive material number
concerned by detonation time.
(Integer) |
- It is possible to define multiple detonation points.
- If a detonation point is not defined, JWL material law will instantaneously detonate.
- Detonation times are available in the Starter output file (IPRI ≥ 3).
- Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
