/DFS/DETPLAN
Block Format Keyword Describes a planar detonation wave.
| /DFS/DETPLAN/detplan_ID/unit_ID | |||||||||
| XP | YP | ZP | TDET | mat_IDDET | |||||
| detplan_ID | Detonator
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| XP | X coordinate for basis
point P Default = 0.0 (Real) |
| YP | Y coordinate for basis
| ZP | Z coordinate for basis
| TDET | Detonation time Default = 0.0 (Real) |
| mat_IDDET | Explosive material number
concerned by detonation time.
(Integer) |
| X coordinate for
propagation direction. (Real) |
| Y coordinate for
| Z coordinate for
- Detonation time is TDET in plane containing basis point P.
- It is possible to define multiple detonators with different types and lighting times.
- If a detonation option is not defined, all JWL material law will instantaneously detonate.
- Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
- Detonation times can be written in the Starter output file for each JWL elements. Printout flag IPRI ≥ 3 (/IOFLAG).
