| Istf |
Interface stiffness
definition flag.
- =0
- Set to 1000.
- 2
- Interface stiffness is the average of the main and
secondary stiffness.
- 3
- 4
- Interface stiffness is the minimum of the main and
- 5
- Interface stiffness is the main and secondary stiffness
in series.
- = 1000 (Default)
- Interface stiffness is only based on the main side
stiffness.
(Integer)
| Igap |
Gap/element option flag.
- =0
- Set to 1
- =1 (Default)
- Variable gap varies according to the characteristics of
the impacted main surface and the impacting secondary
node.
- =2
- Variable gap + deactivating secondary nodes if element
size < gap value, in case of self-impact contact
similar to Irem_gap=2 for
/INTER/TYPE7.
- =3
- Variable gap + size of the mesh is taken into account to
avoid initial penetrations.
(Integer)
| Ishape |
Flag defining the shape of
the gap along free edges.
- = 0
- Set to 1.
- = 1 (Default)
- Square gap.
- = 2
- Round gap.
| Irem_i2 |
Deactivating flag for the
secondary node, if the same contact pair (nodes) has been defined in
interface TYPE2.
- =0
- Set to 1
- =1 (Default)
- Secondary nodes in /INTER/TYPE2 tied
contacts are removed from this contact.
- =3
- No change to secondary nodes.
| Idel |
- =0
- Set to 1000
- = 1
- When all the elements (4-node shells, 3-node shells,
solids) associated to one segment are deleted, the
segment is removed from the main side of the interface.
It is also removed in case of explicit deletion using
Radioss Engine keyword
/DEL in the Engine file.
- Additionally, non-connected nodes are removed from the
secondary side of the interface.
- = 2
- When a 4-node shell, a 3-node shell or a solid element
is deleted, the corresponding segment is removed from
the main side of the interface. It is also removed in
case of explicit deletion using Radioss Engine keyword
- = 1000 (Default)
- No deletion.
| Iedge |
Edge contact options.
Contact occurs between main and secondary edges which are
automatically extracted from surf_ID1 and surf_ID2. Sharp edges for external solid faces are defined using the angle
Edge_angle.
- = 0
- Set to the value defined in
/DEFAULT/INTER/TYPE25
- = 1
- The secondary and the main edges are the external border
edges of shell segments. There is no edge contact for
solid elements.
- = 11
- The secondary edges are the sharp edges of the external
solid segments and external border edges of shell
segments. The main edges are all edges from external
segments.
- = 13
solid segments and all shell segments.
- = 22
- The secondary and main edges are all edges from external
solid segments and all edges from shell segments.
- = 1000 (Default)
- No edge to edge contact.
(Integer)
| Igap0 |
Gap modification flag for
secondary shell nodes on the free edges.
- =0
- Set to 1000
- = 1
- Set gap to zero for the secondary shell nodes.
- = 1000 (Default)
- No change.
(Integer)
| Inacti |
Initial penetration flag.
- =0
- Set to 1000
- = -1
- All initial penetrations are taken into account.
- = 5
- The main segment is shifted by the initial penetration
value
- If
, then
, where
is the initial
penetration.
- = 1000 (Default)
- Only tiny initial penetrations (1.0e-08) will be taken
into account.
(Integer)
