/DEF_SOLID
Block Format Keyword Used to set default values for certain parameters in all solid properties and thick shells. The default values defined here will be overwritten by any values entered on the individual property input.
| /DEF_SOLID | |||||||||
| Isolid | Ismstr | Icpre | Itetra4 | Itetra10 | Imas | Iframe | |||
| Isolid | Solid elements formulation
flag. 2
(Integer) |
| Ismstr | Small strain formulation
flag. 3
(Integer) |
| Icpre | Constant pressure
formulation flag. Only valid when Isolid=14, 17, 18 or 24.
(Integer) |
| Itetra4 | 4 node tetrahedral element
formulation flag.
(Integer) |
| Itetra10 | 10 node tetrahedral
element formulation flag.
(Integer) |
| Imas | Nodal mass distribution
(per element) flag. Only for tetra4 and tetra10 element.
(Integer) |
| Iframe | Element coordinate system
formulation flag. only for standard 8-node bricks: Isolid=1, 2 or 17.
(Integer) |
- This card is read only once. Only the first card /DEF_SOLID written in the model is used. The other card /DEF_SOLID is ignored.
- When using the automatic setting option Ismstr = Icpre = Iframe=-1, the values for these options are defined using the best options based on the element formulation, element type, and material. Alternatively, defining Ismstr = Icpre = Iframe=-2 will overwrite the values for these options defined in this property with the best value (/DEF_SOLID) based on element type and material law. To see the values defined by Radioss, review the “PART ELEMENT/MATERIAL PARAMETER REVIEW” section of the Starter output file.
- Refer to the comments in /PROP/SOLID for more information about these input options.
- If Ismstr= -1, -2, Icpre=-1, -2 or -2; or Iframe= -1, -2, based on different materials, the best property values are set automatically.
- Foam: 1
Material Element Isolid Ismstr Icpre Iframe IHKT h LAW33 HEXA 24/18 2 3 2 1 0 TETRA4/TETRA10 -- 2 0 1 1 0 LAW38 HEXA 24/18 10 3 2 0 0 TETRA4/TETRA10 -- 10 0 1 0 0 LAW70 HEXA 24/18 11 3 2 0 0 TETRA4/TETRA10 -- 11 0 1 0 0 LAW90 HEXA 24/18 12 3 2 0 0 TETRA4/TETRA10 -- 12 0 1 0 0 - Rubber: 1
Material Element Isolid Ismstr Icpre Iframe IHKT h LAW40 HEXA 24/18 2 3 2 0 0 TETRA4/TETRA10 -- 2 0 1 0 0 LAW42 HEXA 24/18 10 1 2 0 0 TETRA4/TETRA10 -- 10 0 1 0 0 LAW69 HEXA 24/18 10 1 2 0 0 TETRA4/TETRA10 -- 10 -1 1 0 0 LAW88 HEXA 24/18 10 1 2 0 0 TETRA4/TETRA10 -- 10 0 1 0 0 - Elasto-plastic material: 1
Material Element Isolid Ismstr Icpre Iframe IHKT h LAW1 HEXA 24 2 3 2 1 0 HEXA 18 2 3 2 0 0 TETRA4/TETRA10 -- 2 0 1 0 0 LAW2 HEXA 24 2 2 2 1 0 HEXA 18 2 2 2 0 0 TETRA4/TETRA10 -- 2 0 1 0 0 LAW36, LAW44
HEXA 24 2 2 2 1 0 HEXA 18 2 2 2 0 0 TETRA4/TETRA10 -- 2 0 1 0 0 - Orthotropic material:
Material Element Isolid Ismstr Icpre Iframe IHKT h dn LAW28 HEXA 1 1 -1 2 0 0 0 HEXA 18 1 3 2 0 0 0 TETRA4/TETRA10 -- 1 -1 1 0 0 0 LAW50 HEXA 1 1 -1 1 0 0 0 HEXA 18 1 2 2 0 0 0 TETRA4/TETRA10 -- 1 -1 1 0 0 0
- Foam: 1
