Auto-Contact Gap Warning
This warning should only be taken into account of a self-impacting interface.
WARNING ID: 94 ** WARNING IN INTERFACE GAP INPUT GAP 1.7 HOWEVER GAP IS RECOMMENDED TO BE LESS THAN 1
Figure 1. Recommended Gap When Modeling Auto-Contact
If the side length, L of an element is lower than the GAP, a self-contact will even be computed from the beginning of the computation.
Such a situation can be accepted if it is an exception, but not for frequent cases over the self-impacting interface. It is possible to localize the source of this message by using a pre-processor and selecting the elements through size criteria.
