/ANIM/CUT/1 (Obsolete)
Engine Keyword Defines a section cut on a deformed geometry.
/ANIM/CUT/1
Name
x0, y0, and z0 nx, ny, and nz V
| Name | Name of the section cut | |
| x0, y0, and z0 | Coordinates of a reference point | |
| nx, ny, and nz | Normal vector | |
| V | Velocity |
- A plane cut is defined in the deformed geometry by the coordinates of a reference point (x0, y0, and z0) and a normal vector (nx, ny, and nz). The plane cut moves along the normal vector with velocity V.
- When using the mass option /ANIM/MASS, the balance displayed in the post-processing is the volumetric flux.
- This keyword is not available for SPMD version.
