/ANIM/BRICK/VDAMi
Engine Keyword Generates animation files containing a damage variable value as the function of a brick element. These output variables are only compatible with failure model /FAIL/SNCONNECT.
/ANIM/BRICK/VDAMi/Keyword4
| VDAMi |
| Keyword4 |
- If ijk=0, the variable is equal to the maximum of the values of all Gauss points in the element.
