Force: Joint Friction
Command ElementThe Force_JointFriction command can be used to modify the parameters of the model element.
Revolute Joint
<Force_JointFriction
  id                         = "integer"
  [ mu_static                = "real" ]
  [ mu_dynamic               = "real" ]
  [ max_stiction_deform      = "real" ]
  [ stiction_trans_vel       = "real"]
  [ inputs                   = "4-bit integer" ]
  [ torque_preload           = "real" ]
  [ friction_arm             = "real" ]
  [ bending_reaction_arm     = "real" ]
  [ pin_radius               = "real" ]
Spherical Joint
  id                         = "integer"
  [ ball_radius              = "real" ]
Translational Joint
  id                         = "integer"
  [ stiction_trans_vel       = "real" ]
  [ inputs                   = "4-bit integer " ]
  [ force_preload            = "real" ]
  [ reaction_arm             = "real" ]
  [ initial_overlap          = "real" ]
Cylindrical Joint
  id                         = "integer"
Universal Joint
  id                         = "integer"
  [ max_stiction_deform      = "real"]
Attributes
id
Element identification number, (integer > 0). This number is unique among all Force_JointFriction elements.
mu_static
Specifies the static friction coefficient, s), in the joint.
MU_STATIC > 0.
mu_dynamic
Specifies the dynamic friction coefficient, d), in the joint.
MU_DYNAMIC > 0.
max_stiction_deform
Specifies the maximum deformation that can occur in a joint for static friction or stiction regime.
stiction_trans_vel
Real value of the absolute velocity below, which the friction transitions from dynamic friction to static friction.
inputs
A 4-bit integer value that specifies the input forces to the friction model. By default, all the preload and joint reaction forces are included. Valid values are 0 or 1 for each bit.
There are four choices to be made:
  • 1st bit: Preload
  • 2nd bit: Reaction_Force
  • 3rd bit: Bending_Moment
  • 4th bit: Torsional_Moment
Setting a 0 or 1 for each bit of the input's value controls individual inputs.
Thus:
  • 1111 - All four inputs are included
  • 0000 - None of the four inputs are included
  • 1000 - Only include Preload
  • 1101 - Include Preload, Reaction_Force and Torsional_Moment, but not Bending_Moment
  • 1001 - Include Preload and Torsional_Moment, but not Reaction_Force and Bending_Moment
Options available per joint type are as defined below:
  • Translational - Preload, Reaction_Force, Bending_Moment, Torsional_Moment
  • Cylindrical, Revolute, Universal, Hooke - Preload, Reaction_Force, Bending_Moment
  • Spherical - Preload, Reaction_Force
force_preload
Specifies the preload friction force for Translational and Cylindrical joints.
torque_preload
Specifies the preload friction torque for Revolute, Cylindrical, Universal and Spherical joints.
friction_arm
Specifies the moment arm used to compute axial friction torque in revolute, universal joints.
reaction_arm
Specifies the moment arm of the reaction torque about the Translation joint axial axes.
Specifies the moment arm to compute the bending moment in Revolute, Hooke and Universal joints.
pin_radius
Specifies the radius of the pin for Revolute, Cylindrical, Hooke and Universal joints.
ball_radius
Specifies the radius of the Spherical joint.
initial_overlap
Specifies the initial overlap of the sliding parts in Translation and Cylindrical joints.
overlap_delta
Specifies friction characteristics in the sliding joint.
INCREASE - Overlap increases as the I Marker translates in the positive direction of the z-axis of the J Marker.
DECREASE - Overlap decreases in the positive direction of the J marker.
