HyperWorks Report 2021 Release Notes
New Features
- Reporting in HyperWorks
- All functionalities are arranged in the Report ribbon. This ribbon is accessible from all applications in HyperWorks.
- Create HTML Reports
- Use the Report tool to create reports in the HTML
(*.html) format. Edit the default master
template or select a predefined master template from the preferences to
generate the HTML report output. HTML format reports can be created from
Predefined reports or Document reports workflows.
Enhancements
- Global Preferences
- Change the default report type and update the master document preferences. This master document is used for all types of Reports created from the session, both Predefined and User-defined Reports.
- Modules and Module Groups
- The following modules have been added:
- Launching Performance
- Report instance launch performance has been improved, launching 50% faster.
Known Issues
The following known issues will be addressed in a future release:
- For the Synchronize feature to work completely in Linux, the report file must be kept closed.
- When a new Excel file path is specified and synchronized on Linux, the file path of the Excel item cannot be synchronized with the report output.
- Session Report in the HTML output format has limitations with TableView and TextView data.
Resolved Issues
- Capture pages and windows modules have some failures with HyperGraph windows.
- On Linux, the table style changed after export.
- Some issues when launching Report from HyperWorks network installations.
