Add a Single Action Draw Operation Simulate a bottom binder holding the blank of a model while the top die deforms the blank against the bottom die. The default tools associated with Single Action draw include a top die, bottom die, and bottom binder. From the Tryout ribbon, click the Add operation icon. From the Add Operation window, select Single Action. The Single Action draw operation is added to the Tryout ribbon. Click the Single Action draw operation. The default tools are displayed. Configure the tools for the Single Action draw. Figure 1. Model Set Up for a Single Action Draw
