Opening the Launcher Utility (Windows)
There are several options available to open the Launcher utility in Windows.
Open the Launcher utility using one of the following workflows:
  • Open the Launcher utility from the Windows start menu:
    1. On the desktop, click the Windows Start button.
    2. Type Feko or WinProp.
    3. Select Feko 2021.2 from the list of filtered options.
  • Open the Launcher utility using the desktop shortcut (if you selected the option to install shortcuts during installation).
