Visibility of Entities
All 3D entities are visible by default (except for named points), provided the model contains the entity.
The entity display options are available on the 3D view context tab, on the Display tab, in the Entities group.
Table 1. Display options for 3D entities.
Icon Name Description
Sources Show / hide sources, such as voltage sources, current sources and plane waves.
Loads Show / hide loads.
Points Show / hide named points.
Probes Show / hide probes, such as voltage probes and current probes.
Cables Show / hide cables.
Networks Show / hide general non-radiating networks.
TX line Show / hide non-radiating ideal transmission lines.
RX antenna Show / hide receiving antennas, such as far field receiving antennas and near field receiving antennas.
