Rendering Settings for Results
View the display settings for simulation results of far fields, near fields, currents and error estimates.
The result rendering settings are available on the 3D View contextual tabs set, on the Result tab, in the Rendering group.
Note: Only the rendering settings relevant to the displayed results are enabled. For example, if there are no near field iso-surfaces displayed, the Colour icon is disabled.
You can apply the rendering options to far fields, near fields, currents and error estimates.
Table 1. Display options for far fields, near fields, currents and error estimates.
Icon Icon text Description
Grid Overlays a mesh grid on the result. Provides a sense of dimension to the 3D results.
Surface Show / hide the coloured surface for the result.
Sampling settings Adjusts the sampling settings for 3D continuous far fields.
Discrete Removes the interpolated colouring of a surface and uses a predefined set of colours to represent the surface.
Colour Specify the colour of the 3D near field iso-surfaces.
Offset Opens the Set display offset dialog for moving the display of the far field origin.
Opacity Specify the amount of transparency.
Size Scale the display of the far field.
Extrusion Specify the extrusion for near field surfaces.
