A report template can be imported from an XML file to reuse in the current POSTFEKO session.
On the Reporting tab, in the
Reports group, click the Import / Export template icon. From the drop-down list select the
Import report template (*.xml) icon.
In the File name field, browse for the XML file to
import.
Click OK to import the XML file and to close the
dialog.
