Mesh Opacity Settings
Specify the mesh opacity as well as the opacity of windscreens triangles and aperture triangles.
The mesh opacity settings are available on the 3DÂ View contextual tabs set, on the
Mesh tab in the Opacity group.
Note: Only the opacity settings relevant are available. For example, if the model does not
contain any windscreens the Windscreen icon is disabled.
Icon | Icon text | Description |
Mesh opacity | Specify the opacity for mesh elements. | |
Windscreen | Specify the opacity for windscreen elements. | |
Aperture | Specify the opacity for aperture elements. |
Note: For all the opacity settings, a drop-down list is available to specify a
custom opacity level. A level of 100% is equivalent to setting no opacity, and 0% is equivalent
to full transparency.
