Changing the Font
Modify the default font and font styling for text on a graph.
Select the graph where you want to change the font.
Change the default font.
  1. Select the text you want to change.
    Tip: To select multiple objects, press and hold Ctrl while you click the items.
    1. On the Format tab, in the Font group, select a font from the Font drop-down list.
  2. Underline the text.
    1. Select the text you want to underline.
    2. On the Format tab, in the Font group, click the  Underline icon.
